08-04-2007 09:32 AM - edited 03-05-2019 05:42 PM
Dear All,
Is it possible to configure InterVlan on 877 series? I tried configuring subinterfaces on Fa 1-3 and failed. Can someone please suggest.
IOS Version:
C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T2.
08-05-2007 08:30 AM
The Fast Ethernet ports on a Cisco 877 are switch ports, correct? That means they need to be configured like a Catalyst switch, not a router.
I've never used any of they 800 series models, but I've used the switch port network modules in the Cisco 3600 series.
In order to get those devices to do what you want, you had to create multiple VLAN interfaces and assign different ports to difference VLANs.
Hope that helps get you started.
08-05-2007 10:48 AM
Yes you can configure interface vlans on a 877 router
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857swcg/eng/index.htm
Narayan
08-05-2007 09:32 PM
Sorry for not explaning what am I going to achieve.
I have Cat 2950 Series switch on which I have configured 5 Vlans. For intervlan communication am trying to use 877 as a router on a stick model.
One of the port (trunk) from 2950 can be connected to 877 Fa port for intervlan routing.
Please advice if am doing mistakes.
Sunoj
08-05-2007 09:31 PM
Sunoj
08-06-2007 02:06 AM
Hai,
U got answers for that question.if not detail me abt the ip address and configuration
08-07-2007 03:33 AM
Please use WAN interface , then it should work (This is the only routed interface).
