2924 - switch#show Ip
Aug 4th, 2007
When I type this command in by using hyperterminal I get the Ip address of 1.
Can anyone explain to me why? I am new in the cisco world and could use your help.
mohammedmahmoud Sun, 08/05/2007 - 10:57
When doing the command "show ip" on a layer 2 switch it shows the number of the management VLAN as illustrated below (which should be 1 by default, any way try changing it as follows):
SW3#sh ip int brief | i VLAN
VLAN1 unassigned NO unset up down
VLAN13 YES manual up up
SW3#sh ip
Mohammed Mahmoud.
llair3333 Sun, 08/05/2007 - 19:49
Thanks a bunch,
From your reply I was able to figure out how to change the ip address, but unfortunately when I turned it off it went back to the orginal. I tried to run the command: copy running-config startup-config, but it did not like it. I have a cisco book and have passed the CNA 5 years ago, but I forgot all of it because the lack of having anything to play with. Is there a place to go to find proper commands for certain devices? Do you know the command I need to save my changes for this 2924 switch? The total memory is not quite 4mb if I am reading this right. Is that what you see?
This is what I am looking at so far:
Switch-4385#show memory
Head Total(b) Used
(b) Lowest(b) t(b)
Processor 45FF1C 3801316 1749908 2051408 1778828 1773128
I/O 70000000 1048576 606784 441792 328436 425692
Switch-4385#show ip
Switch-4385#show ip interface brief vlan1
Interface IP-Address OK? Method Status Prot
Switch-4385(config)#interface vlan1
Switch-4385(config-if)#ip address
Switch-4385#show interface vlan1
VLAN1 is up, line protocol is up
Hardware is CPU Interface, address is 0002.b977.e440 (bia 0002.b977.e440)
Internet address is
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Last input never, output 00:00:50, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
9 packets output, 576 bytes, 0 underruns
0 lost carrier, 0 no carrier
