what is the difference Between CCM 3.3 , CCM 4.X and CCM 5.X
esa786_2
Dear Seniors,
1, I want to know the difference between CCM 3.3 AND CCM 4.1
My second questions
Difference between CCM 4.X and CCM 5.X
pls let me know the above diffrence.
if any body knows , pls answer to my question, it will be helpful to lot of people.
thanks
esa
2 Accepted Solutions
Esa,
I am glad you found the reply helpful. I would urge you to rate any useful post as this scoring system actually encourages individuals like me to remain actively engaged in the forum.
regards
Ajaz
Rob Huffman
Hi Esa,
Just to add a note to the good info you received from Ajaz, I tried to break this down a little bit and narrow down the reading materials. Have a look;
CCM 3.3.4 New and changed Information
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a008020027c.html#wp1319190
CCM 4.1.3 New and changed Information
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/rel_note/413cmrn.htm#wp1708005
CCM 4.2.x New Features
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00805f1470.html#wp2430214
CCM 5.0.1 New and changed Information
http://www.cisco.com/application/pdf/en/us/guest/products/ps6164/c1178/ccmigration_09186a00807043f4.pdf
CCM 6.0.1 New and changed Information
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp44146
Hope this helps!
Rob
5 Replies 5
AJAZ NAWAZ
Level 5
Level 5
Dear Esa,
The answer to your question is going to be fairly detailed. The reason for this is that a very large amount of features are added in each one of the Callmanager version which you have stated. Nevertheless I have located a document which compares them in their entirety and I hope you find it useful:
<http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_software_versions_comparison.html>
Of course the newer (or later) the version - the more features it will have to offer.
hth
Ajaz
Dear Ajaz. Thank you very much for your reply. It is useful and informative and solved my question. Though it is very detailed but lot of info on that link.
Thank you for your help.
Keep helping people.
Esa
Esa,
regards
Ajaz
Rob Huffman
Hi Esa,
Hope this helps!
Rob
Hi Rob.Thank you for your help. This also very useful.it is giving new features of all the major version.Thank you once again. Keep it up
esa
