e1 is not responding
Aug 4th, 2007
I have MWR1941 router . This router has VWIC-2MFT-E1DIR. It has a default y cable configuration. My problem is associated with e1 . MY card is not sending any singnal. Please advise.Pls check the sh controller and sh run
royalblues Sun, 08/05/2007 - 00:04
The controller shows loss of frame.
Make sure the framing matches at both ends. Try chnaging it to framing no-CRC4 under the controller confguration and test
Paolo Bevilacqua Sun, 08/05/2007 - 00:31
There are also loopbacks on the line and because this appears to be a professional installation for mobile neetwork, you probably have a maintenance department that should look into that.
royalblues Sun, 08/05/2007 - 08:13
Still loss of frame.
also saw alarm incoming signal as well. You need to check the parameters at both ends
bikash_bd Mon, 08/06/2007 - 20:07
Dear Narayan,
I have solved the problem yesterday night and sorry inform you. I had to reconfigure it.
