bgp as path reqexp
Answered Question
Aug 5th, 2007
hi everyone, i was reading ccie exam cert bt wendell odom and got confused in one of its examples. its from page 435 table 13-5.
reg exp is ^123_.*_45$
"An AS_PATH beginning with AS 123 and ending in AS 4, with atleast one other AS in between."
i think its bit wrong coz . is followed by * which means zero or more occurence of the preceding character now if there is no character between 123 and 45 then its also valid isnt it ? so why its saying that atleast one AS between them ?
am i wrong in my understanding ? kindly tell me.
Correct Answer by mohammedmahmoud about 9 years 9 months ago
Theoretically speaking you are right, ".*" means zero or more, but the fact that you have "_" before and after it, and thus this regular expression can't match 123 45, as this one has only one space between the 2 ASs, then practically this regexp will only match when there is at lease one AS in between.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Sun, 08/05/2007 - 01:35
  • Green, 3000 points or more
HTH,
Mohammed Mahmoud.
mohammedmahmoud Sun, 08/05/2007 - 02:11
hi Ovais,
You are very welcomed :) and thanks for using the rating system.
HTH,
Mohammed Mahmoud.
