6500 modules
Aug 5th, 2007
Dear All
I have a problem on two 16 GIGA ethernet modules on 6500 swithch, the servers connected on these modules couldnt see each other and they on the same vlan, when i put the servers on the same module they see each other.
IOS 12.2(18)zxd6
thank you in advance
Edison Ortiz Sun, 08/05/2007 - 11:25
  • Hall of Fame,
    Founding Member
Can you post config along with the show mod from this switch ?
Pavel Bykov Sun, 08/05/2007 - 12:28
  • Silver, 250 points or more
Also, be sure the port configuration is the same. That they are all switchports, duplex settings etc.
Have you tried pinging something else than other servers? like default gateway/IPs of other VLANs or some other destination?
