failover ISDN backup link
amcocisco
I have situation where half of my network is connected with one central location and other half with second central location. Every router is connected with primary frame-relay link and ISDN as backup link (floating static route conf).
I need to configure that in case backup link can't manage to connect with one central location start connection with second central location. Failover ISDN backup link. Any sugestions? Thanks
paolo bevilacqua
Configure the two numbers under dialer interface. These will be tried in sequence, and in fact if things are configured properly it will be no problem if some branches are connected to primary hub and some to secondary.
I have diferent addressing on secondary location, but I think that this can be solved using another Dialer in remote offices and secondary IP address in central location. I will test soon this using mora one static route with bigger admin. distance in remote offices.
