IOS update
Answered Question
Aug 5th, 2007
hi
weve got a 3640 router with this ios version ..IOS (tm) 3600 Software (C3640-IS-M), Version 12.0(7)XK2
does anybody knows with which version i can update this one ? thanks
Correct Answer by jwdoherty about 9 years 7 months ago
Also take note of your router's flash and RAM memory values. Often limits, unless you upgrade, what IOS you can use too.
Correct Answer by mohammedmahmoud about 9 years 7 months ago
Please use Cisco Feature Navigator to find information about your platform and the supported Cisco IOS software image with your required features:
http://www.cisco.com/go/fn
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Sun, 08/05/2007 - 10:20
  • Green, 3000 points or more
HTH,
Mohammed Mahmoud.
Correct Answer
jwdoherty Mon, 08/06/2007 - 07:27
