Cisco MSFC2
Answered Question
Aug 5th, 2007
Hello Everyone
I have an MSFC2 cat6500. It has 3 vlan's VLAN 201, 202 & 203. What commands can I use to move a port from one vlan to another?
Also, from the above question it should be obvious that my MSFC knowledge really suck. I understand that the device can run in IOS mode or MSFC mode. How do I determine which one I am running in.
And last but definitely not the least, some URL's with technical explanations as well as command refs will be highly appreciated.
Thank You :)
wvw
Correct Answer by JORGE RODRIGUEZ about 9 years 5 months ago
Hi Willem, In Mohammed's post and links is well explained and suggest go over those links.
Another quick way to determined if the switch is running hybrid or native you could do the following:
Connect to the switch through local console.. usually when the switch is running in hybrid the 1st device you connect is the switch engine and you can recongnize right away by the prompt.
e.g
swithc6509>enable
switch6509(enable)
you can issue "show version " and "show mod"
show module will provide modules installed, including the MSFC doughter card that is installed in the Sup1A blade being listed as modules 15 slot1 .. module 15 is your MSFC card router, you can connect to it from the switch by issuing " session 15 " command and connect to the router.. if you get this far it is crear you are running in hybrid.. to get back into the switch press ctrl-c several times to be back to switch engine.. if all these steps proves to be true you can assign or change port vlan assigments as :
switch6509(enable)set vlan 201 mod/port
or several ports from a single module
e.g
switch6509(enable)set vlan 201 3/1-10
also "show port" will list all ports and their vlan assigments.
If you don't get any of the above results and all your prompts indicate a router prompt that may be running in native issue following commands ..
in native mode all RJ45 ports can either be plain layer 2 port or routed ports and if so you will see ports configure as " switch port mode access " or no switchport mode access " and possibly with an IP address configured.
switch6509>enable
switch6509#show run
to assign/change vlans on a port
simply do as follows:
SW6509#config t
SW6509#interface fastethernet3/25
SW6509(config-if)#switchport mode access
SW6509(config-if)#switchport access vlan 201
Jorge
Correct Answer by mohammedmahmoud about 9 years 5 months ago
hi,
Your Catalyst can run either in Hybrid or Native modes. In the hybrid mode, two separate image files are managed by the two different operating systems. The CatOS images are stored on the Supervisor bootflash or flash cards (PCMCIA for Supervisor 1A and Supervisor 2, and Compact Flash for both the Supervisor Engine 32 and Supervisor Engine 720). The Cisco IOS image for the MSFC is stored on the MSFC bootflash.
As for the Native mode Cisco IOS Software requires the single image be present on a device local to the Supervisor because it is a bundled image for two processors and the SP boots first. The image can reside either on the Supervisor bootflash (sup-bootflash:) or the flash card (slot0: or disk0:); it cannot reside on the MSFC bootflash.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml#dram
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a00800c8441.shtml
For configuring VLANs:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008019f024.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a7c.html
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Sun, 08/05/2007 - 10:25
hi,
HTH,
Mohammed Mahmoud.
Correct Answer
JORGE RODRIGUEZ Sun, 08/05/2007 - 11:32
e.g
swithc6509>enable
switch6509(enable)
e.g
switch6509>enable
switch6509#show run
SW6509#config t
Jorge
