08-05-2007 12:25 PM - edited 03-03-2019 06:11 PM
We have just set up a VPN (well almost) between my office in the UK and our US office. We need to connect to resources on the US side from the UK.
The US team have provided the equipment to do this, problem is we have a few networks our side that are the same IP range as the US so we wondered if we could NAT the UK traffic to a range that none of us have? Here is the setup:
2 external IP's, 1 connects to a firewalls outside port, the other to another firewalls outside port (we have 2 firewalls for redundancy) the inside ports of the firewalls connect to a 1811 router (Fast Ethernet 2 and 3). The 1811 routers Fast Ethernet 1 port connects to our LAN and has an IP of 192.168.17.1. We route the UK traffic that needs the US resources to 192.168.17.1.
Can we NAT all our traffic that passes through the LAN port on the 1811 to an IP NAT Pool so the US see our traffic as one range? I assume it would have to be the range of the the 1811 LAN port range (192.168.17.0/24)?
That way no the US only see us from one range that doesn't clash with their subnets.
08-05-2007 12:31 PM
Sure, I've done this before. This document explains it clearly, just eliminate the IPSec config.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800b07ed.shtml
08-05-2007 12:49 PM
Thanks but I don't have any control over the 1811 config, I will need to email the US that possibility we can NAT our UK traffic, could you just paste the bit I need to change and I will email them it this is all new to me?
Or/also
If they are not prepared to change their config, cold I use my spare 1841 cisco router and put it between the 1811 and out LAN to the inside is our LAN and the outside is the 1811?
08-05-2007 01:37 PM
Both sides need the NAT config. At the US side, you can NAT 192.168.17.0/24 to 192.168.117.0/24 with the following commands:
At the ingress interface
int f0/0
ip nat inside
At the egress interface
int s0/0
ip nat outside
The nat command
ip nat inside source static network 192.168.17.0 192.168.117.0 /24 no-alias
You will need to do the same in the UK, you can use 192.168.217.0/24
Replace all instances for 192.168.117.0/24 with 192.168.217.0 from the above config.
You need routes (either dynamic or static) pointing to those networks. From the US, you need a route to 192.168.217.0/24 pointing the UK and from the UK you need a route to 192.168.117.0/24 pointing to the US.
Keep in mind, to the US the 17.0 network at the UK is now 192.168.217.0/24 and can not be reference as 192.168.17.0 - same idea lies behind devices being reference from the UK to the US.
HTH,
08-05-2007 01:39 PM
Andy
I'm still a little unclear what your are trying to do.
If you want to NAT all your internal traffic to 192.168.17.x then please see config from previous post.
What are the networks you need to access in the US ? Whatever the subnets are just add them to the access-list in the previous post.
You will only need to do something different if you need to talk to a machine in the US that has the same IP address as a machine in the UK but so far you haven't said that is a requirement.
Jon
08-05-2007 09:39 PM
Hi Jon, sorry I could locate my other post via my blackberry.
It really is that simple, we really don't want our networks to clash, so we just want to Nat all the UK traffic on the UK 1811 that is also builds the tunnel from the uk to us.
The 1811 just connects to our uk LAN so anything through the lan port to the us can use an IP Nat pool, so the us will only see one range from the uk.
I have another idea as the us team control the 1811. I have a spare 1841 router, can I somehow put the inside port of the 1811 into the 1841 and then the inside of the 1841 into our LAN and get this to do all the Nats? Then the US can leave their router and this other router can just do the Nat?
08-06-2007 06:34 AM
If the US are reluctant to change anything on their 1811 router, is it possible to put the inside LAN port from that into the outside of my spare 1841 then put the 1841 into our LAN to do the NAT? Is this config ok for this scenario?
Current configuration : 1684 bytes
! Last configuration change at 14:31:17 London Mon Aug 6 2007
! NVRAM config last updated at 14:31:18 London Mon Aug 6 2007
version 12.4
service password-encryption
hostname NATrouter1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone London 0
clock summer-time London date Mar 30 2003 1:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
ip domain name yourdomain.com
username ********* privilege 15 password 7 ********
interface FastEthernet0/0
description *** LAN INTERFACE ***
ip address 192.168.9.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description ** OUTSIDE INTERFACE TO US 1811 Router **
ip address 192.168.17.1 255.255.255.0
ip nat outside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.9.254
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool UKpool 192.168.9.2 192.168.9.250 netmask 255.255.255.0
ip nat inside source list 101 pool UKpool
access-list 101 permit ip any 170.50.10.0 255.255.255.0
snmp-server community ******** RO
snmp-server host 192.168.x.x *****
control-plane
line con 0
password *********
login
line aux 0
line vty 0 4
privilege level 15
password *******
login
transport input telnet
line vty 5 15
privilege level 15
password ******
login local
end
08-06-2007 06:44 AM
Andy
Yes you can do this. Your access-list 101 does not look right though. Are you saying that you want all traffic wherever it is going to be Natted to 192.168.9.2 -> 250 ?
If so
access-list 101 permit ip any any
If not let me know
Jon
