Static vs. Route?
Aug 5th, 2007
Can someone tell me the difference between "static(inside,outside)..." and "route...." ?
Overall Rating: 4 (3 ratings)
mattiaseriksson Mon, 08/06/2007 - 00:00
The static command creates a persistent one-to-one address translation rule by mapping a real IP address to a mapped IP address.
The route command simply enters a static or default route for the specified interface.
Does that answer your question?
homeboarder8 Mon, 08/06/2007 - 07:32
Okay, so basically static is for IP addresses and route is for interfaces?
Jon Marshall Mon, 08/06/2007 - 07:41
Not quite. They are both dealing with IP addresses.
The static command does a translation from one IP address to another.
The route command tells the firewall where to send packets that go through it eg.
On a pix you usually have a default route "ISP ip address" where ISP address is the next hop towards the internet from your firewall.
This tells the pix that any traffic that it doesn't have a more specific route for send to the ISP router.
acomiskey Mon, 08/06/2007 - 08:14
I think the confusion for beginners here is drawing a similarity between a "static command" and a "static route". These are completely unrelated.
