cisco 3845 with NM-1CE1TE
Aug 5th, 2007
Hi dear all
i have a cisco 3845 router with nm-1ce1t1
module. the module is fine but when I pulg it to my router, it doesnt work!!
even the led on module doent turned on.
the ios version is not my problem cause i have the latest one.
spremkumar Sun, 08/05/2007 - 21:34
  • Red, 2250 points or more
Can you post the output of show version and show diag here ?
regds
emadehsan Sun, 08/05/2007 - 22:29
yourname#terminal monitor
*Aug 6 06:21:56.171: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:01.543: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:06.911: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:12.279: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:15.975: %C3800_ENVM-3-MFAIL_OFF: There is more than one failure wi
th the Power System 1 or this Power System has been turned off.
*Aug 6 06:22:17.647: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:23.015: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:28.383: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
*Aug 6 06:22:33.755: %OIR-3-SEATED: Insert/removal failed for slot 3, check car
d seating
yourname#sh ver
Cisco IOS Software, 3800 Software (C3845-IPBASE-M), Version 12.4(4)T4, RELEASE S
OFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 03-Aug-06 14:55 by kellythw
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
yourname uptime is 8 minutes
System image file is "flash:c3845-ipbase-mz.124-4.T4.bin"
Cisco 3845 (revision 1.0) with 222208K/39936K bytes of memory.
Processor board ID FCZ103873EQ
6 FastEthernet interfaces
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
yourname#sh diag
3845 Backplane EEPROM:
Hardware Revision : 1.0
Top Assy. Part Number : 800-23093-01
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC10341CH8
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Part Number : 73-8639-04
CLEI Code : IPME110BRA
Chassis Serial Number : FCZ103873EQ
Product (FRU) Number : CISCO3845
Version Identifier : V01
Hardware date code : 20060823
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 01
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 30 33 34 31 43 48 38 03 00 81 00 00 00 00 04 00
0x30: 82 49 21 BF 04 C6 8A 49 50 4D 45 31 31 30 42 52
0x40: 41 C2 8B 46 43 5A 31 30 33 38 37 33 45 51 CB 92
0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20
0x60: 20 20 89 56 30 31 20 83 01 32 1A 97 FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Backplane Registers
Backplane Revision: 00BE
Power Supply Status: 0BEF
-48V PS and Env Status: FFFF
-48V Isolation Control: 0007
Backplane Cookie: 000C
ENM/Backplane FPGA Revision: 00BE
ENM/Backplane FPGA Int0 Status: FFFF
ENM/Backplane FPGA Int2 Status: 00FF
ENM/Backplane FPGA Int4 Status : EF00
ENM Interrupt Mask: 000B
ENM/BP FPGA Interrupt 4 Mask: 0040
spremkumar Sun, 08/05/2007 - 22:32
hi
Is it possible to switch off the router and insert the card ?
can you try the same and check whether the card is getting detected..
regds
emadehsan Sun, 08/05/2007 - 22:55
i have tried this issue
turned off the router
and insert the card into every slot
the result was same
laso my ios is ipbase version
spremkumar Sun, 08/05/2007 - 23:25
I did try checking out for the ios compatibility with the hardware you are using out there but i would still suggest to key in the features you require and the additional hardwars cards you are using out over there in the tool to find out the comaptible ios for your router..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
paolo bevilacqua Mon, 08/06/2007 - 01:41
  • Hall of Fame,
    Founding Member
The NM is not recognized in show diag. Either It has been damaged during insertion with power on, os something else is wrong.
Andyfweih Mon, 08/13/2007 - 02:59
Dear business partners & valued customers :
I am pleased to enclose it for your reference.
We can give you better price depending on the items and Qty.
Large quantity new & used Cisco and networking products that aren't
included in this catalogue. Feel free to contact us with your
requirements.
50% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-24TS-S
WS-C3560-48TS-S
WS-C3560G-24TS-S
WS-C3560G-48TS-S
WS-C3750-24TS-S
WS-C3750-48TS-S
WS-C3750G-12S-S
WS-C3750G-24TS-S
WS-C3750G-24PS-S
60% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-48TS-E
WS-C3560-24TS-E
WS-C3750G-24T-E
WS-C3750G-24TS-E
WS-C3750G-24PS-E
WS-C3750G-48TS-E
WS-C3750G-48PS-E
CISCO1841 $630
Looking forward to receiving your enquiries soon.
Best Regards
Andy Feng
FEDON(INT'L)DEVELOPMENT LTD
MSN:[email protected]
Email:[email protected]
Http://fweih.diytrade.com
