CallManager 5.1(2) and Cisco OU in AD
Aug 6th, 2007
Hi all, after migrating from 4.X to 5.1(2), i want to delete the "Cisco" OU from our AD. Could it be done safely ?
I think all informations previously stored in that OU are now in CallManager local LDAP DB.
Thanks a lot.
Julien.
espereir Sat, 09/08/2007 - 23:23
  • Silver, 250 points or more
Since the LDAP integration changed on CCM 5.X and now we have MLA enabled by default, the CCMAdministrator, CCMSysUser and the accounts previously stored on AD, are now hosted on the local directory database, you can safely delete the Cisco OU if you are not using it, just remember to perform a Directory Synchronization after doing that.
Check this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a008063748a.html#wp1049989
Hope this helps!
