ASA,s with side to side VPN and EIGRP
Aug 6th, 2007
Hi folks,
i have a problem with a customer project: Today they have a airlink 34Mbit connection to a other building and wish now to secure this link.
I have read on CCO that the 8.x software now can work with EIGRP. I need this because this is a EIGRP Network. So my problem is how to setup a VPN IPsec Side to Side connection that works with EIGRP. The SIde to Side is very easy (using ASDM) but what do i need to setup EIGRP to going over this Side to Side?
Building1 Router-- ASA--AIRLINK--ASA--Router2. The other problem is that they use a backup dark-fiber link 10Mbit for redundance and on the side from router1 they send with the EIGRP command variance 2 packets over the Airlink and over the backup link and all answers going back over the airlink.
any suggestions about this ?
Your help is greatly appreciated.
Klaus
Overall Rating: 4 (1 ratings)
Collin Clark Mon, 08/06/2007 - 11:24
  • Purple, 4500 points or more
You can enable EIGRP routing on the ASA just like on a router (ie router eigrp ). The variance command allows unequal cost load balancing. You might want to do something like a floating static route for failover. Be careful with running EIGRP on an ASA, you can propagate unwanted routes. I prefer to not use a routing protocol on the firewall and just use the traditional ACLs.
HTH and please rate.
ksimsimon Wed, 08/08/2007 - 01:52
Hi HTH ,
thanks for your answer.the problem is that i need the EIRGP.Is it possible to use a GRE-Tunnel on both routers and send the EIGRP traffic over the side to side tunnel? so then the traffic over the airlink-connection is secure and the routing proccess works also right ?
