Adding Devices (SNMPv3) - Cisco LMS 2.6
Aug 6th, 2007
Hello everybody!
I'm having problems adding devices in Cisco LMS. Those devices are using SNMPv3. Everything seems to be working normal when I execute
snmpwalk -v 3 -u ciscolms -l authPriv -a MD5 -A ciscolms -X ciscolms XXX.XXX.XXX.XXX
However, when I add a device in LMS, it is placed in "Questioned" devices, and the following debug message is received:
Aug 6 14:34:53: SNMP: Get request, reqid 67181, errstat 0, erridx 0
system.1.0 = NULL TYPE/VALUE
system.2.0 = NULL TYPE/VALUE
system.4.0 = NULL TYPE/VALUE
system.5.0 = NULL TYPE/VALUE
system.6.0 = NULL TYPE/VALUE
Aug 6 14:34:53:
Incoming SNMP packet
Aug 6 14:34:53: v3 packet security model: v3 security level: auth
Aug 6 14:34:53: username: ciscolms
Aug 6 14:34:53: snmpEngineID: 8000000903000019E8AC3290
Aug 6 14:34:53: snmpEngineBoots: 1 snmpEngineTime: 602068
Aug 6 14:34:53: SNMP: Response, reqid 67181, errstat 16, erridx 0
Could you please tell me what might be causing the problem?
Best Regards,
Vladislav Vasilev
Overall Rating: 5 (1 ratings)
frankzehrer Mon, 08/06/2007 - 03:55
  • Silver, 250 points or more
Hi Vladislav,
authpriv will maybe not supported in LMS 2.6 and is still not supported in LMS 3.0. For LMS 3.0 there will be a patch coming until the end of this year.
Until then use AuthNoPriv.
Hope that helps.
Best regards,
Frank
v.vasilev Mon, 08/06/2007 - 05:56
Hello Frank,
Thank you very much for your prompt reply!
It's working now :)
Best Regards,
Vladislav
