2950 Cisco Catalyst Switch
ShaunieK226
Was wondering if a Catlayst 2950 can SPAN the G0/1 and G0/2 ports as well as all the 10/100 Ethernet Ports.
Shaun
Yes, you can use it, that should not be a problem.
~JG
Jagdeep Gambhir
Level 10
Level 10
Shun,
You can have only one destination port.
?The destination port cannot be a source port; a source port cannot be a destination port.
?You can have only one destination port.
?For SPAN source ports, you can monitor sent and received traffic for a single port or for a series or range of ports.
It can have only one active SPAN or RSPAN source (rx, tx, both).
Hope that helps
~JG
Thanks, Yeah I am aware that I can only have 1 session with a 2950 Series Switch. I just needed confirmation that I can use the Gibabics ports as source ports. I will be using E1/1 for my Snort box/destination port.
Shaun
~JG
