Alternative to Call Redirect
Aug 6th, 2007
In the CCO documentation it states, if Call Redirect is used (i.e. to VM), it can cause double counting in reports. It states to use the Select Resource Step instead to avoid this. Does anyone know how that would be achieved with Select Resource (possibly what that part of the script would look like)? Thanks.
Chris Deren Mon, 08/06/2007 - 09:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
can you point us to the document you are referring to?
I don't see how it's possible with select resource step.
Chris
