08-06-2007 05:22 AM - edited 03-10-2019 03:44 AM
Could anyone tell me where I can get evaluation version of the CSA profiler? I did not see it in the download page.
Nitass
Solved! Go to Solution.
08-06-2007 08:07 AM
The profiler/amalysis piece is included in the software download, you just to install the evaluation license for it.
Tom
08-06-2007 08:07 AM
Tom
08-06-2007 08:12 AM
Thank you so much Tom. Is it the Cisco Security Agent Analysis license?
Thanks again,
Nitass
08-06-2007 11:09 AM
Hi Nitass
Yes, that's what they call profiler now.
Tom
08-06-2007 07:20 PM
Thank you very much for your kind.
Have a nice day,
Nitass
08-25-2007 03:38 AM
Tom,
Did you ever try to use the Profiler or hear of anybody who did?
I was curious because our customers usuallly balk at the price. If it really was so good Cisco probably should have included it in order to distinguish its product from the rest of the Host-based IPS products.
Just my 2 cents.
If anyone has experience with the Profiler please post your opinion.
All responses will be rated.
Thanks!
08-27-2007 10:31 PM
Hi Paul, I use the Cisco Security Agent Analysis (used to be Profiler) now for application behavior investigation.
I didn't like Profiler much because it created rulesets that were very restricted (it only allowed the app being profiled and nothing else).
It works much better now because you can enable app behavior and deployment investigation for hosts or groups and go through it when needed.
I haven't dug into it fully but it seems to work better than it used to.
Tom
