HTTP POST question
Aug 6th, 2007
Hello All,
Iam currently working on creating services for the cisco ip phones. Iam using IP communicator2.0 with call manager 3.0.I have a requirement by which i want to push an alert onto the phone screen without the services button of the IP communicator being pressed. Iam aware that the web server can send a HTTP POST onto the communicator. But iam not sure whether the web server of the IP communicator is running or not. Iam not able to receive any request to port 80.
Is the web server of the IP communicator running on a different port? or is there any other work around to acheive an XML object push onto the IP communicator.
Stephen
msabir Mon, 08/06/2007 - 05:52
  • Bronze, 100 points or more
Web server runs on IP communicator on the same port as IP phones -- that is port 80 by default. I am able to do HTTP Post on IP communicator and run CiscoIPPhoneExecute object on it.
stephenwalter Tue, 08/07/2007 - 05:06
Thanks for the response it was actually the firewall that was causing the issue i disabled it and was able to communicate with phone's web server
Anyway i was able to send a POST to the phone's web server and also got a 200 OK response for it with an xml body as . But the XML object that
i added to the POST is not getting displayed on the phone. The following is the POST request i had sent to the ip phone
POST /CGI/Execute HTTP/1.1
Host: xxx.xxx.xxx.xxx:80
Connection: Close
Date: Mon, 06 Aug 2007 09:05:38 GMT
Server: Microsoft-IIS/6.0
X-Powered-By: ASP.NET
Authorization: username="suresh"
Content-Type: text/xml
Content-Length: 204
Cache-control: private
Title
Select the option
Menu
http://xxx.xxx.xxx.xxx/CiscoServices/airline/airlines.asp
Let me know if there is an issue with the POST request
stephenwalter Thu, 08/23/2007 - 03:06
Hi guys,
Sorry for the late response. I tried adding the URL as an CiscoIPPhoneExecute object like
http://xxx.xxx.xxx.xxx/Login.aspx?/>
and Iam getting the following response
HTTP/1.1 200 OK
Date: Thu, 23 Aug 2007 05:26:57 GMT
Cache-Control: no-cache
Expires: Wed , 25 Oct 1995 18:30:00 GMT
Content-Length: 32
Server: Allegro-Software-RomPager/4.20
="0" />
but no GET operation is being done for the URL i give in the Execute Item tag. Am I missing something here?
regards,
Stephen
stephan.steiner Tue, 08/28/2007 - 00:35
  • Silver, 250 points or more
What makes you think that if you get back something that contains the word error, the operation has been properly executed? It hasn't.
Error 0 is one of the elusive ones you can't quite properly track down.. usually it is solved by rebooting the phone or the cluster.
