WPA Key on cisco 871w router
Aug 6th, 2007
Where do i find my wpa key on my router?
ssid Guest
vlan 20
Authentication open
Authentication key -management wpa
wpa-psk ascii 7 053b071c325b411c9d
Is this my Key: 053b071c325b411c9d
dbentley Mon, 08/06/2007 - 05:38
The 7 tells you that the presharedkey is encypted.
wpa-psk ascii 0 (then the passphase without qoutes)
wpa-psk ascii 0 securewirelessnetwork
jkawyn Mon, 08/06/2007 - 07:22
will this show me my wpa key when i put this cli in? ineed the key for my wirelss card.
wpa-psk ascii0 securewirelessnetwork
Im from rochester ny also but i moved to charlotte,Nc and I miss Wegmans Stores and Nick Tahou's
dbentley Mon, 08/06/2007 - 07:28
If you have service password-encryption on your router (which you should have) you will see the key when you type it but it will be encrypted afterwards.
Yes, Wegmans and Nicks are key here!!!
jkawyn Mon, 08/06/2007 - 07:47
Im lost!!!!!!!! Just starting my ccna!!!!!!
Can you give an example how it would look in CLI. Using Password for wpa encryption
jkawyn Mon, 08/06/2007 - 10:10
I get this part
wpa-psk ascii 0 password
after i put this cli in, Where is my wpa key located?
