WS-X6348-RJ-45 Card Problem
Aug 6th, 2007
I recently purchased a replacement WS-X6348-RJ-45 card for my 6509
platform. When I slide the card into the chassis the card powers up,
then after a minute or two it powers itself down. It does the same
thing if the "power enable" command is issued. The log shows only
the following output:
*Aug 6 11:06:44: %C6KPWR-SP-4-ENABLED: power to module in slot 7 set
on
*Aug 6 11:08:14: %C6KPWR-SP-4-DISABLED: power to module in slot 7 set
off (admin request)
I'm running IOS version 12.1(8b)E20 with 7 more of these same cards in
the unit functioning fine. I've tested the slot with a known good
card and it works fine. I have also moved the questionable card to
known good slot and it does the same thing. At this point I either
have a bad or incompatible card. The only reason I say incompatible
is because of the hardware rev shown when I do a "show module" is
quite a bit higher than the others as seen in the output below:
Mod Ports Card Type Model
Serial No.
1 2 Cat 6000 sup 1 Enhanced QoS (Active) WS-X6K-SUP1A-2GE
SAD041104EX
2 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAL04493Z8M
3 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAD04310BW9
4 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAD04250183
5 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAD041600UT
6 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAL04493Z8M
7 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAL0808UPCW
8 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAL0437186M
9 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45
SAL04341PAV
Mod MAC addresses Hw Fw
Sw Status
1 0030.9631.ebd4 to 0030.9631.ebd5 3.1 5.1(1)
6.2(2.113) Ok
2 0003.6c15.1aa0 to 0003.6c15.1acf 1.4 5.4(2)
6.2(2.113) Other
3 0002.fc62.2c10 to 0002.fc62.2c3f 1.1 5.3(1)
6.2(2.113) Ok
4 0030.b63a.cf10 to 0030.b63a.cf3f 2.1 5.4(2)
6.2(2.113) Ok
5 00d0.d3a1.9208 to 00d0.d3a1.9237 1.1 5.3(1)
6.2(2.113) Ok
6 0003.6c15.1aa0 to 0003.6c15.1acf 1.4 5.4(2)
6.2(2.113) Ok
7 000f.240b.89f4 to 000f.240b.8a23 9.0 Unknown
Unknown Other
8 0001.9756.91d0 to 0001.9756.91ff 1.4 5.4(2)
6.2(2.113) Ok
9 0002.fc1c.a178 to 0002.fc1c.a1a7 1.1 5.4(2)
6.2(2.113) Ok
Mod Sub-Module Model Serial
Hw Status
1 Policy Feature Card WS-F6K-PFC SAD042702D9
1.1 Ok
1 MSFC Cat6k daughterboard WS-F6K-MSFC SAD041009E0
1.4 Ok
As you can see the card in question, card 7, is on hw rev 9.0 which is
quite a bit higher than the rest. What I don't know is if this is the
problem or if I have a bad card. I haven't been able to find a
matrix saying what hw revs are supported by what software revs.
Can anyone shed some light on this for me?
Mike
Overall Rating: 4 (1 ratings)
Edison Ortiz Mon, 08/06/2007 - 12:16
  • Hall of Fame,
    Founding Member
You've done your homework. It's a faulty hardware. Call Cisco and ask for a RMA.
