ACS 4.0 SE TCP/UDP port duplication
Aug 6th, 2007
Hi I am running 2 ACS servers on the SE platform running 4.0(1) Build 42. On one server everything works fine, but on the other server I get this:
TCP Ports Opened
49 opened
2000-2003 opened
1075 opened
49 opened
2000-2003 opened
1075 opened
UDP Ports Opened
68 opened
1645-1646 opened
1812-1813 opened
68 opened
1645-1646 opened
1812-1813 opened
As you can see, the ports are duplicated. If I restart the services, it is a 50/50 chance on whether the ACS server will process authentications.
Jagdeep Gambhir Mon, 08/06/2007 - 07:47
If one acs shows no duplicate ports then it seems to be some software of hardware issue on the box.
I would suggested you to reimage it and see if issue is still there.
If it is , then I would suggest to get it RMA'd.
~JG
klouthan Mon, 08/06/2007 - 08:14
I am pretty sure this is a result of the DELIVERANCE1 bug, but thought I would ask anyway. Thanks, I will go ahead and open a TAC case.
Jagdeep Gambhir Mon, 08/06/2007 - 08:18
I don't think this is due to delv1 bug but lets wait and see what TAC has to say.
