msabir Mon, 08/06/2007 - 09:33
  • Bronze, 100 points or more
So instead of CallManager, you are running as asterisk based call processing engine? In CCM, Idle Url can be changed at the enterprise level or at the phone level. So I imagine, in trixbox, it would be where the phone gets it's initial configuration options. For example, in CCM simulator, you can setup the default phone configs including authentication and idle url.
dannyleshaba Wed, 08/08/2007 - 02:50
I seem to be having serious problem. my trixbox configuration dont have an option for idle url,only logo,xm service and directory url are present..
Anything that i can do to overcome this proble caus ei realy want to have my service runningon an idle url. instead of having to click the service button.
Danny
msabir Wed, 08/08/2007 - 05:03
You can write a script to "push" your application to IP phone or use speed dials as service URLs.
dannyleshaba Tue, 08/14/2007 - 00:41
Not sure how to go about coding a scipr for pushing application.
I am using php but can port easily to asp.
throw some ideas..
Danny
msabir Tue, 08/14/2007 - 07:58
Pushing to phone is simple a HTTP POST. Instead of HTML, you have to post XML. Checkout CiscoIPPhoneExecute object from Cisco's SDK for IP phones. You can do it in PHP, Java, or .Net. I do have code in Java.
