WISM upgrade
Aug 6th, 2007
i need to upgrade the IOS in wism frome where i can download this image please help
rob.huffman Mon, 08/06/2007 - 10:39
Hi Ahmed,
Here is some info to get you started with this Upgrade process;
Q. I plan to upgrade my WiSM to the latest software version. Is there any recommended procedure to upgrade the WiSM?
A. A WiSM upgrade follows the same procedure involved in the upgrade of a 4400 Series Controller. Since a single WiSM module contains two 4400 controllers in it, you need to individually upgrade both WiSM controllers.
From this good Q & A doc;
Wireless LAN Controller (WLC) Software Upgrade to Versions 3.2, 4.0, and 4.1
Here is the link to the Downloads Page (need CCO Login);
Hope this helps!
