What command does RME issue on device(s) to backup configs
Answered Question
Aug 6th, 2007
Telnet is the protocol used. What command or commands does RME use to backup device configs?
Correct Answer by Joe Clarke about 9 years 11 months ago
The output from the device is captured into an accumulator buffer by the sync archive process, then written out to a temp file. That file is then moved into the archive location, and the database is updated.
Overall Rating: 5 (3 ratings)
Joe Clarke Mon, 08/06/2007 - 11:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Assuming an IOS router device:
terminal length 0
terminal width 0
show privilege
terminal no monitor
enable
show running-config brief
show running-config
show startup-config
Note: not all commands will be used on all versions of IOS or all router device types.
getwithrob Tue, 08/07/2007 - 04:18
I don't understand how the output is captured from the show running and show startup commands then saved in a file(s) on the RME servers.
Correct Answer
Joe Clarke Tue, 08/07/2007 - 04:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
