Switching Methods
Answered Question
Aug 6th, 2007
How can i change the switch from Store-and-Forward to Cut-Through or to Fragment-Free mode?
or is it something that you cant change and have to buy a second switch?
Correct Answer by Richard Burts about 9 years 9 months ago
Oren
To supplement the response from William: there were switches in the Cisco product line if you go back in history which supported cut-through or fragment free forwarding. As the product line has evolved it has consolidated on the store and forward methodology. The references to cut-through and fragment free which may be found in some training material and perhaps in some certification tests are historical anachronism.
Rick
Overall Rating: 5 (1 ratings)
wochanda Mon, 08/06/2007 - 17:06
  • Silver, 250 points or more
All Cisco switches are store-and-forward. This isn't configurable.
Contrary to what the certification exams will have you believe, there isn't any noticeable performance hit for this.
Correct Answer
Richard Burts Mon, 08/06/2007 - 19:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Oren
Rick
ajay_bhard2002 Tue, 08/07/2007 - 05:02
HI this IT engineer,As per requirement I could suggest u to do the CCNA course and take the certification exam
Richard Burts Tue, 08/07/2007 - 05:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Oren
Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read questions and can know that they will read what resolved the question. I encourage you to continue your participation in the forum.
Rick
