Bandwidth on 3725
Aug 6th, 2007
I have a 3725 router and I need help doing the following
I need to monitor our DS3 usage.
I also need to limit the bandwidth to about 10 Megs.
Please advise
Paolo Bevilacqua Mon, 08/06/2007 - 17:19
  • Hall of Fame,
    Founding Member
To monitor, suggest you prtg (search) that is free for personal use up 1 router.
To limit bandwidth, if you own both sides of the link, enter under interface "dsu bandwidth . But, to not waste the link is better to limit only certain traffic using a shape or rate-limit command that is done via QoS (a little more advanced).
Hope this helps,please rate post if it does!
spremkumar Mon, 08/06/2007 - 19:30
  • Red, 2250 points or more
As paul mentioned you can make use of prtg since its gonna be a single interface.
http://www.paessler.com/prtg
You can also monitor the traffic on the link/port using show interface command and check out the same...
regds
