Network Monitoring
Aug 6th, 2007
I need a software to monitor my network devices. I need to monitor the activities on each switch and router. I also need to monitor my UPS and the room temperature. I need to get e-mails when there is an alert or temperature drop.
Please advise.
Thank you
Pavel Bykov Tue, 08/07/2007 - 08:46
  • Silver, 250 points or more
Depends a lot on size and budget.
MRTG is free, but you have to be a bit skilled in PERL to make it do your biddings.
Commercial solution we use is Concord eHealth. It has a straightforward interface to set up all your thresholds and warning procedures, including emails.
bamnocadmin Tue, 08/07/2007 - 09:02
I use WhatsUp Gold for monitoring all my network and servers. PRTG is great for bandwidth. Scrutinizer is my NetFlow Analyzer.
Thanks.
chris.king@csu-... Fri, 08/10/2007 - 07:11
Hi there,
I use OpManger. Its free for a limited amounts of nodes and works on windows or linux. There are also some intigrated cisco modules available.
Chris
