Difference between CCM 4.1(3) & 4.3(1)
Aug 6th, 2007
What is the difference between these two. Preparing for Voice exam and CCM 4.1(3) is the stated version. How much of a disadvantage am I if I only have access to 4.3(1)?
mchandak Tue, 08/07/2007 - 00:47
If you are referring to CCIE Voice, then I'd personally recommend using CM 4.1(3). It is always better to use the version of CM which is being tested. There are differences, esp multiple feature enhancements which change the way you would configure the same in CM 4.1.
Try to get yourself a copy of CM 4.1(3). That will always be the best bet
d.chulhan Tue, 08/07/2007 - 04:36
I have been looking for the last 2 monts, however, no luck. If you have any ideas on where to look, please let me know.
