why client can't use sametime and download mail
Aug 6th, 2007
when a wireless client join to the WLAN(1200AP(lightweight)+LanController2006+Swith+Router),all of the wireless client can't use sametime ,and user cant download it when the mails are over 3kB.but user can visit all the web information by IP address.
otherwise,if the WLAN is only AP1200(weight)+Swith+Router,user can user sametime and download all the mails.
help me!thx.
goldtechcco Sun, 08/12/2007 - 23:44
first thks.
1:there is not any acl configured for the wlan;
2:we have upgrade the controller,but the question still;
3:next is the controller config.please confirm it.
(Cisco Controller) >show running-config
802.11a cac voice tspec-inactivity-timeout ignore
802.11a cac voice stream-size 84000 max-streams 2
802.11a channel global off
802.11a txPower global 1
802.11b cac voice tspec-inactivity-timeout ignore
802.11b cac voice stream-size 84000 max-streams 2
802.11b fragmentation 1272
advanced location expiry tags 1200
advanced location expiry client 150
advanced location expiry calibrating-client 30
advanced location expiry rogue-aps 1200
Cisco Public Safety is not allowed to set in this domain
country CN
dhcp create-scope wireless-dhcp-test
dhcp address-pool wireless-dhcp-test 10.135.30.40 10.135.30.50
dhcp default-router wireless-dhcp-test 10.135.30.254
dhcp enable wireless-dhcp-test
dhcp dns-servers wireless-dhcp-test 10.136.30.201 10.136.30.202
dhcp domain wireless-dhcp-test intranet.icbc.com.cn
dhcp netbios-name-server wireless-dhcp-test 10.136.30.201 10.136.30.202
dhcp network wireless-dhcp-test 10.135.30.0 255.255.255.0
interface create vlan 72 72
interface address ap-manager 10.143.3.250 255.255.255.0 10.143.3.254
interface address management 10.143.3.249 255.255.255.0 10.143.3.254
interface address virtual 1.1.1.1
interface address dynamic-interface vlan 72 10.135.30.250 255.255.255.0 10.135.30.254
interface dhcp ap-manager primary 10.143.3.249
interface dhcp management primary 10.143.3.249
interface dhcp dynamic-interface vlan 72 primary 10.143.3.249
interface vlan vlan 72 72
interface port ap-manager 1
interface port management 1
interface port vlan 72 1
logging buffered 1
mesh security eap
mgmtuser add admin **** read-write
mobility group domain cisco
mobility symmetric-tunneling enable
msglog level critical
network telnet enable
network broadcast enable
network mgmt-via-wireless enable
network rf-network-name cisco
radius auth add 1 10.139.115.3 1812 ascii ****
radius auth add 2 10.11.115.3 1812 ascii ****
radius auth rfc3576 enable 1
radius auth rfc3576 enable 2
snmp version v2c enable
snmp version v3 enable
sysname Cisco
wlan create 2 WPA_PRO TEST2009
wlan interface 2 vlan 72
wlan aaa-override enable 2
wlan broadcast-ssid disable 2
wlan radius_server auth add wlan-id:2 global server index:1
wlan radius_server auth add wlan-id:2 global server index:2
wlan security static-wep-key encryption 2 104 ascii **** 1
wlan security wpa wpa1 enable 2
wlan security wpa wpa1 ciphers tkip enable 2
wlan security wpa wpa2 disable 2
wlan dhcp_server 2 0.0.0.0 required required
wlan enable 2
c.netherton Mon, 09/17/2007 - 12:54
I have had similar problem. It only appeared when I changed the default speed settings. WLC was advertising some 802.11 speeds even when they were 'disabled'. Try with all WLAN speeds "supported" and see if problem is still there.
Christopher
goldtechcco Fri, 09/28/2007 - 00:47
sorry,can you give me more about the "default speed settings",i have changed some speed ,but the problem is still.
thanks.
