Which is better 5505 or 501 security appliance ????
Aug 6th, 2007
HI
I have some branches which is connected HO . 501 pix configure in branch. only two server are static map by pix and this two server are access from outside.
Now i have found new product ASA 5505.
now 3 small branch are add my network.
so I purches pix 501 or ASA 5505 ?.
which is better for me.
Biplob
srue Tue, 08/07/2007 - 02:54
  • Blue, 1500 points or more
moving forward, purchase the 5505..it will be supported longer than the 501 will be...
If the 501's are doing everything you need them to be doing at the other sites though, you shouldn't have any reason to replace them.
