show command
Aug 6th, 2007
does anybody know if there is a show command that displays all the prefixes in the BGP table that match a specific extended community route target?
Thanks in advance
Stefano
Overall Rating: 4.5 (2 ratings)
mheusing Tue, 08/07/2007 - 03:12
There is a little trick: you define an extended community list specifying the RT and then use it with your show command, f.e.:
Router(config)#ip extcommunity-list standard CheckRT permit rt 65535:1
Router(config)#end
Router# show bgp vpnv4 unicast [all|rd|vrf] community-list CheckRT
Depending on your IOS version, the command syntax might vary slightly, but the ? is your friend ;-)
You can also use regular expressions within extended community lists. For the complete usage please check
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a0080454ced.html#wp1074763
Hope this helps! Please rate all posts.
Regards, Martin
