VPN client pix intermittent connection?
Aug 7th, 2007
I have set up the confi below, but sometimes I can connect and sometimes I cannot, people in different places can connect and not connect at the same time. Can anyone spot anything obvious.
Many Thanks.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name xxxxxxxx
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list 100 permit ip
access-list nonat permit ip
access-list NONAT permit ip
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 218.x.x.218
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool RAS-DAN mask
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0 0
route outside 218.x.x.219 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
crypto ipsec transform-set dan1 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 100 set transform-set dan1
crypto map APS-MAP 1 ipsec-isakmp
crypto map APS-MAP 1 match address 100
crypto map APS-MAP 1 set peer
crypto map APS-MAP 1 set transform-set dan1
crypto map APS-MAP 100 ipsec-isakmp dynamic dynmap
crypto map APS-MAP interface outside
isakmp enable outside
isakmp key ******** address netmask
isakmp identity address
isakmp nat-traversal 20
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
vpngroup DANRAS address-pool RAS-DAN
vpngroup DANRAS dns-server
vpngroup DANRAS wins-server
vpngroup DANRAS default-domain xxxx.local
vpngroup DANRAS split-tunnel 100
vpngroup DANRAS idle-time 1800
vpngroup DANRAS password ********
telnet timeout 5
ssh xxx.xxx.xxx.xxx outside
ssh timeout 60
console timeout 0
terminal width 80
srue Fri, 08/10/2007 - 09:08
why such a small pool for vpn users?
next time someone can't connect, see how many people are already on.
johnroche_2 Mon, 08/13/2007 - 05:13
what model of PIX are you using, if its a 501 you can probably only connect 10 users at any one time
srue Mon, 08/13/2007 - 05:40
That's more of a licensing issue. But you bring up a valid point. We probably need to see a "show ver" output.
