08-07-2007 01:39 AM - edited 03-05-2019 05:45 PM
Dear Sir,
Where can I find the spec of GBIC WS-G5484. Is it LC interface and support auto-negotiation?
Thanks!
Solved! Go to Solution.
08-07-2007 02:07 AM
This GBIC is SC interface and supports auto-negotiation.
Here is the link for further details
http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a008014cb5e.html
Shaheen
08-07-2007 01:43 AM
Hi Joseph
Yes it supports auto-negotiation and no it isn't an LC connector it is an SC connector.
Jon
** Edit - apologies Joseph but on second thoughts not entirely sure abou auto-negotiation. I think this is more to do with the port capability rather than the connector **
08-07-2007 01:53 AM
HI Joseph,
Cisco Catalyst WS-G5484
INFO: It is an SC Connector and not LC.
Whereas i don't know whether this support Auto-Negotiation or not
Pls refer "Jon" recommendations for the same.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
08-07-2007 02:07 AM
Shaheen
