router product code
Answered Question
Aug 7th, 2007
hello
does anybody know how i can find the product code of a router?
Correct Answer by Majdi Harb about 9 years 7 months ago
do u mean the part number of a router
if yes, then for example u can find part numbers for 2800 series router from the data sheet for any version type on:
http://www.cisco.com/en/US/products/ps5854/index.html
specifically for 2821 router:
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
or if u have cco access to dynamic ordering tool from:
http://www.cisco.com/en/US/ordering/index.shtml
hth
/majdi
Correct Answer by Jon Marshall about 9 years 7 months ago
Hi Bill
Do you mean the code you use to order the router.
If so go to the following link
http://www.cisco.com/en/US/products/hw/routers/index.html
From there select the router you want info on. On the next page click on data sheets and within the data sheets there are the codes for the routers and any interfaces etc. that are available for that model.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 08/07/2007 - 03:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Bill
Jon
bkoum Tue, 08/07/2007 - 03:35
im trying to allocate the ios attributes from a search engine and it ask the product code...
Correct Answer
Majdi Harb Tue, 08/07/2007 - 03:27
  • Silver, 250 points or more
hth
/majdi
