VLAN
Answered Question
Aug 7th, 2007
Hi sir ,I have been completed my CCNA course,and I have a doubt on it,if you configure on switch with 4 VLAN and another switch with 3 VLAN and when you want to connect between the VLAN switches we use trunk port to communicate,am i wright,if it is wright how to configure the trunk port and where do you configure it ?and also I am attaching the diagram please verify and tell me send me the configuration of two diagrams?
Correct Answer by Jagdeep Gambhir about 9 years 10 months ago
Ajay,
AAASWITCH(config)#vlan 37
AAASWITCH(config-vlan)#exit
AAASWITCH(config)#vlan 50
AAASWITCH#show vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
Fa0/25, Fa0/26, Fa0/27, Fa0/28
Fa0/29, Fa0/30, Fa0/31, Fa0/32
Fa0/33, Fa0/34, Fa0/35, Fa0/36
Fa0/37, Fa0/38, Fa0/40, Fa0/41
Fa0/42, Fa0/43, Fa0/44, Fa0/45
Fa0/46, Fa0/47, Fa0/48, Gi0/1
Gi0/2
30 VLAN30 active
35 VLAN35 active
37 VLAN0037 active
50 VLAN0050 active
101 VLAN0101 active
107 VLAN0107 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
~JG
Overall Rating: 4 (2 ratings)
Jagdeep Gambhir Tue, 08/07/2007 - 05:20
  • Red, 2250 points or more
Ajay,
Congrats for your CCNA.
On Switch 1 , choose any port that you want to connect to Switch2
Let says I take port 0/1
Switch one,2950
SWITCH(config)#interface fastEthernet 0/1
SWITCH(config-if)#switchport mode trunk
Switch Two, 2950
Your trunk port is ready.
~JG
Please rate if helps
ajay_bhard2002 Tue, 08/07/2007 - 05:25
Hi ~JG ,
Thanks for your answer I have been satisfied and also want to know that one example of creating vlan ?please answer it.
Correct Answer
Jagdeep Gambhir Tue, 08/07/2007 - 05:31
Ajay,
AAASWITCH#show vlan
Gi0/2
30 VLAN30 active
35 VLAN35 active
37 VLAN0037 active
50 VLAN0050 active
101 VLAN0101 active
107 VLAN0107 active
~JG
