port-security with voice vlan "Sticky"
Aug 7th, 2007
I have the following :
Why does the Cisco 7960 phone NOT put a sticky mac address automatically under the switchport, just the PC does?
It seems to work, but am not sure why.
Also, I dont require "maximum macs" to be set to 3 do I? Like when you use Avaya?
Many thx indeed,
interface FastEthernet1/0/10
description IP Phone with desktop connected
switchport access vlan 10
switchport mode access
switchport voice vlan 20
switchport port-security
switchport port-security maximum 2
switchport port-security mac-address sticky
switchport port-security mac-address sticky aaaa.bbbb.cccc
no ip address
duplex full
speed 100
priority-queue out
no mdix auto
switch#sh mac-address-table int fa 1/0/10
Mac Address Table
Vlan Mac Address Type Ports
10 aaaa.bbbb.cccc STATIC Fa1/0/10
20 dddd.eeee.ffff STATIC Fa1/0/10
Total Mac Addresses for this criterion: 2
b.hsu Mon, 08/13/2007 - 05:59
the normal procedure is to set max mac-address to 3 for port security
kfarrington Mon, 08/13/2007 - 06:06
Hi there :)
Well I read this all the time, but my Cisco IPTs work with the setting of only two, and if I increase the maximum to 3, is this not creating a security hole?
Many thx for the reply and look forward to more comments :))
e.huntley Mon, 08/13/2007 - 06:52
You have to do 3 because when the phone first boots up in goes into the default VLAN, not the voice VLAN. Once CDP kicks in, it goes into the voice VLAN
kfarrington Mon, 08/13/2007 - 06:56
Umm. still a tad confused as all of my phones are working, as SecureDynamic and my PCs are SecureSticky, but I did configure the port-sec after the phone had been booted.
I think I will need to take a walk to where the phones are and power cycle the phone, to see if it breaks?
Will get back to you shortly :))
Cheers to all
tgryting Sun, 11/14/2010 - 15:36
Cisco Foundation Learning Guide pg 347 - "switchport port-security mac-address sticky" command cannot be used on ports where voice VLANs
are configured...(although the book does not elaborate as to why not...)
