EoMPLS with no P router(s)
Aug 7th, 2007
Pls help clarify the following things:
1. Can I do an EoMPLS psedowire b/w two directed PE routers? I think of PHP behavior, but we can disable PHP!!
2. Pls see the topo
Agg using 7609, sip400 with 2ge uplink, ws.6724.sfp downlink
n.PE using 7609 also, sip600 with 2x10ge for corelink, ws.6724.sfp downlink, sip600 10x1G to BRAS (not shown)
'Cause sip400 doesn't support VPLS, so we intend to deploy E-LAN (EMS) service by lauching EoMPLS from Agg, terminate at n.PE & start VFI fullmesh from here to other n.PEs.
Can I do this? If yes, how can I do xconnect command on n.PE?
Really need yr help & tks!
swaroop.potdar Fri, 08/10/2007 - 06:48
  • Blue, 1500 points or more
You can do Eompls without a P device between 2 back to back PE's.
You can configure the xconnect on an SVI interface for the SP vlan.
HTH-Cheers,
Swaroop
