CSAdmin do not stop
Aug 7th, 2007
Hi, I have a problem...
I'm trying to upgrade my ACS from 4.1.3.12 to 4.1.3.12.2, but the CSAdmin service do not stop.
Is there any bug in this version (4.1.3.12)?
Plataform: ACS Appliance 1111
Help me!
Cristiano
Jagdeep Gambhir Tue, 08/07/2007 - 06:30
  • Red, 2250 points or more
How you are trying to upgrade it ? There is no need to stop csadmin in acs appliance.
~JG
CSCO10729468 Tue, 08/07/2007 - 06:39
Hello JG... Thanks for your quick reply!
I'm trying to upgrade through serial connection, using the commands:
- download
The download is performing. Ok!
After that I insert the command:
- upgrade
So the proccess try to stop all services before begin the upgrade, but the CSAdmin service don't stop.
The following error is displayed:
!!! Failed to stop CSAdmin !!!
Any idea?
Cristiano
Jagdeep Gambhir Tue, 08/07/2007 - 06:53
Make sure CSA is disabled before you try to upgrade. Also did you try to upgrade via GUI ?
CSCO10729468 Tue, 08/07/2007 - 13:52
Hi JG...
Unhappyly I did not get success in my attempts.
The solution was to remove the 4.1.3.12 and to install the 4.1.2.12 version...
Now my ACS's are ok...
Thanks for your attention!
Cristiano
