DHCP excluded addresses
Answered Question
Aug 7th, 2007
I configured the Router to a specific DHCP pool . I put also the default gateway, name server etc. After that i configured to exclude some specific range of addresses. But when i write show dhcp ip pool ... i can not see the excluded addresses. How can i find them . Do i have to remember them or write them down.
Moses.
Correct Answer by Richard Burts about 9 years 9 months ago
Moses
If you do show run you should see the excluded addresses as part of the running configuration. You could also do show run | include excluded
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 08/07/2007 - 07:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Moses
Rick
ankbhasi Tue, 08/07/2007 - 07:17
  • Cisco Employee,
Hi Moses,
You can see them in your running config.
"sh run | in exclude"
Ankur
sundar.palaniappan Tue, 08/07/2007 - 07:35
  • Green, 3000 points or more
Moses,
Both Rick and Ankur have provided the info to find the dhcp excluded address from the config.
To answer your specific question as to why the excluded address info doesn't show up with the 'show dhcp ip pool' command is because all the other values like network, default router, dns etc are configured under the dhcp pool mode whereas the excluded address is configured under the global config mode.
Sundar
