VPN
Cisco CyberSecurity
Labels
Hi! The last weeks it has been a big increase of brute force attempts from all over the world to our Cisco ASAs. We use two factors, so we're not to afraid that they will actually access any of our accounts, but the problem is that they manage to blo...
Sonflaa by Level 1
  • 213 Views
  • 9 replies
Following upgrading to upgrading to 5.1.2.42 to fix the vulnerability CVE-2024-20337Within Microsoft Defender this is still flagged as vulnerability for the CVEIt appears to refer to a component of the install:C:\Program Files (x86)\Cisco\Cisco Secur...
ansto by Level 1
  • 307 Views
  • 10 replies
As per the CVE, the detailed information is available in the advisory : Cisco Adaptive Security Appliance Software and Firepower Threat Defense Software Remote Access VPN Unauthorized Access Vulnerabilityhttps://sec.cloudapps.cisco.com/security/cente...
Jay Kumar by Cisco Employee
  • 15848 Views
  • 4 replies
Working on VPN and we are getting errors stating no TP found.  Did a sh ssl/ sh run ssl and got weird information back but need help with understanding TP's
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 754 Views
  • 31 replies
The following message is displayed when the connection button is pressed. Please tell me how to solve it. Certificate Validation Failure   AnyConnect VPI version 5.0.04232 Secure Client UI version 5.0.00889 Certificate Expiration Date 2025/4/3
Translator by Community Manager
  • 78 Views
  • 1 replies
Hi, We are trying to implement Azure SAML SSO on our Firepower 1010. We are using ASA 9.19.1 and Secure client 5.0.02075. When we try the login via Azure by clicking the "Test this applicaton" the login works and there are no errors in the logs. The ...
