Extending the # of Rings on a phone
Aug 7th, 2007
Is it possible to extend the # of rings on a particular extension?
Overall Rating: 5 (1 ratings)
rob.huffman Tue, 08/07/2007 - 08:54
Hi Rob,
In CCM 4.X and above you can set this at the Directory Number Configuration page on a per device basis:
**No Answer Ring Duration - This option allows you to configure the CFNA timer per **DN, per cluster.
The default is 12 seconds (4 rings) I beleive.
Hope this helps!
