Are the requirements for CCSP changing?
Answered Question
Aug 7th, 2007
I went to a boot camp to get CCNA training (worth every dime - I missed one question on the ICND). Now I'm thinking of pursuing a CCSP through self-study. While reading book reviews, I saw a couple that said they are changing the exams around for CCSP. I don't want to spend money and time studying something I don't need; what, if anything is changing?
Also, is there a preferred order to take the CCSP exams, or can I skip around?
Correct Answer by compsolv about 9 years 5 months ago
Yes. They HAVE changed!
Cisco is moving to a Core/Elective format for CCSP.
Core:
SND, SNRS, IPS, SNPA
Current Electives:
HIPS, CANAC, MARS, CSVPN
Check it out here at:
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
Anthony J. Sequeira
#15626
Correct Answer by glenncosta about 9 years 5 months ago
Hello Jason,
Well the prefered way is to first answer SND, you can then answer the SNRS/PIX/IPS/CSVPN exams in any order that you wish to.
Overall Rating: 5 (2 ratings)
Correct Answer
glenncosta Tue, 08/07/2007 - 09:43
Hello Jason,
hamilton-jason Tue, 08/07/2007 - 12:35
I suppose I'll just take the "core" exams plus the CSVPN, then save the other "elective" exams for recertification later.
Thanks for the help, that was exactly what I was looking for.
