Support for Vibrate Feature with XML Applications
parisatashakori
Hi everybody,
I've just realized that vibration feature is added as an xml URIs. Based on 7920 Release Notes for Firmware 3.01:
With firmware release 3.01, the Cisco Unified Wireless IP Phone 7920 can now receive a URI message from a third party XML application that activates the vibrate device on the phone. You can use these parameters to customize the vibration sequence:
Vibrate Duration?Sets the vibrate-on interval in milliseconds
Silence Duration?Sets the vibrate-off interval in milliseconds
Count?Sets the number of times to repeat the vibrate on/off sequence
Syntax for the vibrate URI is:
Vibrate:[{vibrateDuration}:{silenceDuration}:{count}]
I am testing a 7920 with cmterm_7920.4.0-03-01 firmware which is newer that 3.01.
When I pushed Vibrate URI with this
<ExecuteItem Priority="0" URL="Vibrate:[1000:1000:5]"/>
I got error number 3 which is internal file error.
Anybody has tried this feature?
I appreciate all your feedbacks,
Parisa
parisatashakori
Just an update that error number 3 is solved. It was a temporary error and with a restart it is gone now. However, phone does accept this uri but does not vibrate.
Can you help me find the missing part?
Parisa
