Multi Access Network
Answered Question
Aug 7th, 2007
what does this term mean? can you give me an example?
sorry for the noobish question
Correct Answer by Richard Burts about 9 years 8 months ago
Oren
A multi access network is a network which can have multiple (more than 2) machines participating in the network. A point to point network can have only 2 and a multi access network can have more than 2. The most common example of a multi access network is Ethernet (and FastEthernet etc).
Rick
Overall Rating: 4.5 (2 ratings)
Correct Answer
Richard Burts Tue, 08/07/2007 - 10:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Oren
Rick
Edison Ortiz Tue, 08/07/2007 - 10:42
  • Hall of Fame,
    Founding Member
Multi-Access Network is often referred to a shared medium, like a hub/switch where multiple devices can connect and share resources. In the WAN, you have Frame-Relay/MPLS/ATM networks where devices share the same Frame-Relay/ATM/MPLS switch.
