3750 Cisco Catalyst
Aug 7th, 2007
Have a question about Cisco 3750 Catalysts. If I have stacked switches, say 3 3750's stacked together, what is the maximum throughput from switch to switch I can get. From what I am reading I can get up to 64 Gbps. Is this true because I am also seeing just 32 Gbps???
Shaun
Jon Marshall Tue, 08/07/2007 - 10:32
Hi Shaun
If you have 3 x 3750 stacked together you will get 32Gbps with Stackwise technology.
i believe you can get up to 64Gbps with Stackwise Plus which runs on the 3750-E switches although if you mix 3750-E with 3750 it negotiates down to Stackwise and 32Gbps again.
Jon
