Edison Ortiz Tue, 08/07/2007 - 10:38
ip nat outside is used when you want to translate the address coming from the outside network into the inside network.
Usually, you only translate ip addresses from your internal network since they are private addresses and devices in the internet have no reachability to them.
So for instance, 192.168.1.1 -> 64.210.210.1 as it exits the router to the internet. That's what the ip nat inside does.
Now, the ip nat outside will be something like
192.168.1.1 <- 64.210.210.1
The address will be translated to an internal address.
To the internal network, they won't be connecting to 64.210.210.1 but to 192.168.1.1 when they need resources from that device in the internet.
HTH,
milkdroogy Tue, 08/07/2007 - 10:50
Does someone use this(the outside conversion...)
? and for what purpose?
sanyaolu Tue, 08/07/2007 - 12:12
Yes, Infact i used it for my company's client "B".
The reason for using this is My company is a large organisation and we have a dedicated Link between My company and our client B. Client B has Private RFC 1918 IP addresses which is not routable in my company. Hence, my company translate the Client Private IP address to a routable IP in my company.
This is one example where you do IP NAT OUTSIDE ........
Adeolu
Edison Ortiz Tue, 08/07/2007 - 12:25
The times I've seen ip nat outside is when translating ip addresses from remote connections that may overlap your network.
For instance, after a merger between 2 companies , IP addresses may overlap and you may want to have the control on what ip addressing scheme is used on incoming packets rather than relying on the remote network engineer to do the translation for you as it exits his/her network.
