Separate Ringlist.xml
Aug 7th, 2007
Does anyone know if it is possible to keep multiple ringlists? For example, department A is only allowed RingList1 and department B is only allowed RingList2. Any incite would be great, thanks!
wbreitzke Mon, 08/13/2007 - 11:34
The RingList.xml file defines an XML object that contains a list of phone ring types. Each ring type contains a pointer to the PCM file used for that ring type and the text that will display on the Ring Type menu on a Cisco IP phone for that ring. The C:\ Program Files\Cisco\TFTPPath directory of the Cisco TFTP server for each Cisco CallManager contains this file
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c2efa.html
arcaidy76 Mon, 08/13/2007 - 16:29
  • Bronze, 100 points or more
I don't know of any way to do it within CCM, but you might be able to set up different TFTP servers and point the phones to then via DHCP and manage it that way. If the groups you want to have seperate ringlist files are in different networks, this might work. Otherwise it would probably be a pain to manage VLAN's based on prefered ringlists.
Just an idea...
