VPN
Cisco CyberSecurity
Labels
Hello, we're running Cisco Anyconnect 4.2 NAC to connect to our VPN. I'm running into an issue where it's telling me that there are no network adapters. I've tried uninstalling/re-installing the network adapter drivers, Cisco NAC and I just can't get...
We are having an issue were after disconnecting from AnyConnect and connecting the next day, they get a new IP in AnyConnect but in our local DNS they have another IP which I assume is probably from the day before. This obviously causing name resolut...
jf1134 by Level 1
  • 106 Views
  • 5 replies
Hi, We are trying to implement Azure SAML SSO on our Firepower 1010. We are using ASA 9.19.1 and Secure client 5.0.02075. When we try the login via Azure by clicking the "Test this applicaton" the login works and there are no errors in the logs. The ...
Hello Team,I have below topology : -I have ipsec vpn from on-prem to aws cloud. the two endpoints  [192.168.40.10/32, 192.168.30.10/32] work fine as they are allowed on the encryption domain.I have users using remote vpn to connect to on-prem dc to a...
fmugambi by Spotlight
  • 197 Views
  • 14 replies
Hello, Is it possible on Cisco FTD managed by Cisco FMC define multiple DH Group in Phase2 ? From what i see it is just possible one. I tried put , but it doesnt accept. Also looking maybe for option to add thorugh flex config but didnt find any rel...
qsscisco by Level 1
  • 335 Views
  • 9 replies
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
I have multiple AnyConnect connection profiles for various remote users that provide access to different internal networks. The authentication method needs to be certificate only, but there doesn't seem to be a way to prevent an issued certificate ho...
Crag Muer by Level 1
  • 200 Views
  • 8 replies
  • 1 Helpful votes
Hi! The last weeks it has been a big increase of brute force attempts from all over the world to our Cisco ASAs. We use two factors, so we're not to afraid that they will actually access any of our accounts, but the problem is that they manage to blo...
Sonflaa by Level 1
  • 271 Views
  • 9 replies
