IDENTIFYING A SWITCH ROOT BRIDGE
Aug 7th, 2007
Hi guys please help me. Which Cisco IOS command do you enter on a switch to enable you to see which switch is currently the root bridge when there are so many switches and spanning tree is enabled?
hardiklodhia Tue, 08/07/2007 - 22:03
  • Bronze, 100 points or more
hi,
show spanning-tree detail / show spanning-tree summary can be used to know abt root bridge for that spantree valn instance.
rgrds,
guruprasadr Tue, 08/07/2007 - 22:09
  • Gold, 750 points or more
Hi, [ PLS RATE if HELPS ]
"show spanning-tree root"
!!Display the STP Root information for all VLAN's configured on a switch.
Other commands for your referenece:
show spannning-tree summary totals
!!Display STP summary information for all VLANs configured on a switch
!!Display detailed STP information for all VLANs configured on a Switch
show spanning-tree vlan vlan-id bridge
!!Display STP bridge information for a specified VLAN
PLS RATE if HELPS
Best Regards,
Guru Prasad R
